PDR - dash cam
Ty88
Florida, USA
2023 CT5 V Blackwing - totaled in accident. Ordering a 2025
I have started to use the dash cam setting in the PDR system continuously for every time I drive the car. Is there any harm in doing that? I would think not because the system allows it but thought I’d ask. 2025 BW. Thanks.
Only wear on the SD card, but it can take hundreds of write/re-write's. No big deal..........they are cheap enough!
Make sure you're using a high endurance / professional SD card that can handle a lot of writes. You don't want to find out that your card has failed when you need it for an accident.
Is there a setting to have it automatically record all the time or do you manually turn it on record every time you start the car?
Yes, there is a setting in the PDR menu to automatically record every time you drive.
There is also a setting (off by default) to overwrite old recordings when the memory card is full - make sure you change that too.
Is there a valet mode for the car?
