Go for Blackwing. Presenting the AWE SwitchPath™ Catback Exhaust for the CT4-V Blackwing:
- Dual 3” valved catback configuration
 - Features AWE’s patented drone-canceling solution,180 Technology®
 - Utilizes factory valve motors to retain all factory drive mode valve functionality
 - Bespoke X-pipe for refined, rasp-free tone
 - Mid-pipes feature bullet-style resonators
 - Dyno-verified gains of +3 hp & +12 lb-ft of torque at the wheels
 - Signature 4.5” double-walled, slash-cut tips available in chrome silver and diamond black
 - Handcrafted from CNC mandrel-bent, U.S.-sourced .065”-wall T304L stainless steel
 - Less is more: clean, straight-through design maximizes performance
 - Pure bolt-on, no-cutting required
 - Perfect Fitment guarantee
 - AWE No CEL guarantee
 - Lifetime Warranty
DUAL PERSONALITIES OF SWITCHPATH™:
Featuring AWE's patented drone-canceling 180 Technology®, the AWE SwitchPath™ brings no drone, minimal bends, maximum flow, and push-button attitude. The SwitchPath™ Exhaust is composed of dual 3-inch U.S.-sourced T304L stainless steel, a precision x-pipe, and a valved SwitchPath™ muffler tuned specifically for the 3.6TT.
Beginning after the factory mid-pipe, the precision X-pipe immediately helps smooth the 3.6TT of its rasp, deepening the tone before it's refined further by the bespoke SwitchPath™ muffler in the rear. Integrated machined valve brackets house the factory valve motors with precision to ensure all of the Blackwing’s valve characteristics remain intact and operate the same as the factory exhaust.
The closed valve experience:
When the valves are closed, the SwitchPath™ Exhaust produces a refined, aggressive howl while remaining full-bodied and powerful – no congested, metallic sounds when on the throttle. At cruising speeds, interior acoustics are close to stock with no drone at cruising speeds. AWE SwitchPath™ tech also responds perfectly to the factory parameters designated by the drive modes, opening the valves when reaching the designated throttle threshold.
The opened valve experience:
Open the valves and the FL4 roar is uncorked. Sport & Track modes achieve the ultimate contrast in behavior when compared to the Tour driving mode (valves closed). In Sport or Track mode, the exhaust note is powerful, clean, and aggressive. Thanks to the precision X-pipe, the rasp is still kept in check while allowing the exhaust note to reach full aggression.
If you’re looking for the best of both worlds (i.e. drone-free, clean aggression), and want to retain your factory valve behavior all while gaining peace of mind (i.e. emissions compliance), look no further than SwitchPath™.
LET’S TALK TIPS:
Finish it off with signature 4.5” double-walled, slash-cut tips in your choice of chrome silver or diamond black—each stamped with the AWE logo and individually adjustable for precise placement.
100% EMISSION-FRIENDLY:
AWE Exhausts do not interfere with any factory emissions equipment.MADE IN PA, USA:
Engineered, designed, and manufactured in-house at AWE using premium US-sourced .065”-wall T304L stainless steel to achieve a tone deeper than everyone else.
THE FINE PRINT:
AWE’s Perfect Fitment Guarantee, No CEL Guarantee, and Lifetime Warranty all come standard.
