CT4-V Oh Strut!
Cadillac CT4-V model
dstewart51
Lake Hughes, CA
23' CT4V-BW
At 63K Miles, it was time to replace both front Magna Ride struts on the Blackwing. Clunk under sharp rebound when stiffened up and they were both leaking. Picked up a cheap $100 spring compressor which made the job easy.
$100? Deets on the spring compressor?
Even from the freight, they were usually twice that.
If you don’t mind, how much is a new strut?
List price per strut is between $650 and $700, they can be found for about half that if you look around. Good to replace the strut upper mount and spring rubbers while your at it. Quote from the dealership was $2650, cost me about $800 to do it myself and I know everything is torqued correctly, cleaned up and not banged around. Need to take it for an alignment now, I just set the upper knuckle bolt for camber adjustment to the middle, so I know my camber will be off.
Free shipping from Texas, I had a coupon code and got a few $ off;
I have the OEM ones compressors, they're great for what they are, but this is awesome.
I still think the prices for what they are is simply the best suspension money can buy? Maybe I am wrong?
$700 is still about 1/3 of what a PASM shock costs. That's not bad.
Is there a service manual? Where did you get the torque specs for the suspension bolts?
That spring compressor looks awesome. I've used the loan a tool spring compressor (Advance Auto) numerous times, but it's a little scary to use.
If you have a friend in the parts dept at the dealer they may be able to pull the torques specs for the upper and lower front and rear suspension.
There are some expendable parts "one time" use once you take the front and rear suspension apart, from what I understand thats a warranty thing. So reuse, if good before good after? Up to you.
The really did copy BMW...
Late to the party, is that disc available for the 5BW? Haven't googled just spotted them. Nice! Diro Discs?
Edit: 63k hell yeah! Looking at her is good, driving her is better!
