Did you ever try or find out? TiaWill 325/30ZR19 tires fit on the rear of the CT5-V Blackwing with the stock wheel offset?
I just put Toyo R888R 325/30/19 on my stock CT5 V Blackwing wheels with 6mm wheel spacers and it works! Hooks like a champ!
The car is sitting a bit uneven bit they are amazing!Any pics?
Where did you get the extra extension on the front splitter? That looks great.I just put Toyo R888R 325/30/19 on my stock CT5 V Blackwing wheels with 6mm wheel spacers and it works! Hooks like a champ!
Hi, I had some questions on your setup as I'm looking at doing something similar.As posted on a previous thread, I did the same thing: Michelin Pilot All Sport AS4 325/30/19 in the rear on OEM wheels with 6mm spacers.
No rubbing at all of the fender. The inside edge of the tire sometimes just barely touches the fender liner -- but just barely & only under severe loading.
Hi, I had some questions on your setup as I'm looking at doing something similar.The car is sitting a bit uneven bit they are amazing!
Did you get longer studs?As posted on a previous thread, I did the same thing: Michelin Pilot All Sport AS4 325/30/19 in the rear on OEM wheels with 6mm spacers.
OE 19" wheels with OE size 275/35Hi, I had some questions on your setup as I'm looking at doing something similar.
- What was your setup (tire size, wheel offset, etc.) for the front
Same as stock bc using the OE sized tire on OE wheel so no rubbing.
- With the front setup, how is the tolerance for rubbing in the wheel well?
I do not think that will work at all. As it is with the spacer and 305/30 on OE 19" wheels, the tolerances are super tight.
- For the rear, do you think there's enough tolerance for 3mm more outward poke on the tire, and 16mm outward poke on the wheel to not touch the fender?
Using the OE studs like others & have not heard of any issues. If I were tracking the car, then I'd definitely use longer studs. But I'm not tracking her with AS tires. YMMV.Did you get longer studs?
If not, did you get 7 full 360° turns on the stock studs?
I would not want to tempt fate with a high HP machine...
Thanks! Being able to compare to your setup, the setup I was intended to do would be too aggressive of an outward poke and will very likely rub, any possible hit the fender. It's great to be able to chat with a community that shares experiences together. Much appreciated!OE 19" wheels with OE size 275/35
