This worked perfectly. Thanks so much.Funny I just did those today. Basically:
1. Turn wheel all the way so you can access.
2. Remove 4 screws in the front of the wheel well (requires a small torx bit, don't remember which size). You may need a shorter driver or ratchet with hex adapter for top one.
3. Pop out liner a bit. I would suggest using a plastic trim tool if possible.
4. Once you can pull liner out a bit using a flash light you can kind of see what is going on.
5. You just need to unclick the one double tab, first push down on the top bit and you will probably hear small click, then push up on bottom bit and you should hear another small click and then push it out. If this doesn't work you may need to push on both sides at the same time.
6. Push marker out so you can access connector.
7. Push a screw driver into the area with the red tab to push the red tab in then use screw driver to push up black tab that's touching the marker and pull out connector.
8. Connect connector to new marker, push red tab back.
9. Put bottom tab of marker in first then push top in until it clicks.
10. Put liner back in and screw back together.
This literally will take about 5 minutes per marker. Its pretty simple.
