btown
This if for an 2023 CT4-V BW, 9k miles. I'm curious if others have had these issues and were able to resolve them. The dealership's service departments around here are not great, so I like to give very clear guidance on how to investigate and resolve my issues. I was not able to find these specific issues anywhere in the forums.
1. Squeaky seatbelt - this is the most annoying one. At low speeds, if you are passing over undulating bumps that make the car and your body sway side to side, the seatbelt makes a medium pitch squeak. It is LOUD. It sounds a lot like the bed squeaking in hotel room next door (if you get my drift). I have isolated it to when the seatbelt is coming is moving in and out (furling and unfurling) slightly. This same squeak cannot be recreated by just pulling the seatbelt back and forth with your hand. It is a very specific instance when it occurs, but it happens A LOT.
2. Excessive wind noise from the sunroof - when closed, there is a lot of noise once you are at highway speed. I love sunroofs so almost every car I've ever owned has one and this is by far the loudest one at highway speeds when closed. I've closely inspected the seal and the closed position and it seems fine.
3. iPhone charging on the charger pad - 10 secs of charging and then nothing. Worked fine up until a couple of weeks ago and now it doesn't. Case on or off, position, charge level - nothing matters. EDIT - found the thread where this seems to be seen an Apple issue - so never mind![Smile :) :)](data:image/gif;base64,R0lGODlhAQABAIAAAAAAAP///yH5BAEAAAAALAAAAAABAAEAAAIBRAA7)
Thanks
Update: had to go back to the dealer to show the tech how the squeak worked. He was able to diagnose and fix.
Sunroof seals back ordered til march but should solve the issue.
Software is current so stuck w spotty charging.
Thanks
