bl4ck_wng
Seasoned Veteran
- Joined
- Nov 11, 2022
- Messages
- 226
- Location
- Jersey
- V-Series Cadillac(s)?
- 2022 Cadillac CT4-V Blackwing
I have a question regarding a tire replacement and the overall lifespan of these TPC spec PS4S summer tires.
I noticed a huge screw in the shoulder of my rear passenger tire (TPC PS4S) back when I swapped to my winter set. It is 100% non-repairable due to location of the screw. this particular set is the OEM set from factory (purchased Sep 2022) and they have roughly 15-20k miles on them, with zero track time, no burnouts/abuse, etc. I really took it easy with mostly highway use, so there is a good amount of meat still on these tires.
Since it has been nearly three years, should I just replace all the tires, or is replacing just the one acceptable? I fear the other three corners will be at a significantly different point in their lifespan than the new one (3 years old vs new on passenger rear corner) -- despite having solid tread remaining. Then there is the question about the rear diff heating up due to miniscule differences in the OD of the tire from wear
Is the correct move to just order a new set of 4 and start fresh? Maybe just 2 new rears?? Would not mind to save the cash, but I won't say no to all four if its the path of safety!!!
