Instrument Panel Fuse Block. Which fuse locations do you use for ACC+ only power?
pkincy
california
2022 CT4-V Blackwing
I have seen posts recommending F24 and F25, but they are very hard to get to but if that is all we have I will figure out a way. I have also heard that F30 and F31 will work as an ignition on fuse but on my CT4-V BW those are dead when only accessory power is on. I admit I was working in a closed garage so didn't have the motor on but did probe 30 and 31 with my multimeter when the car was in accessory mode and got nothing. Constant battery 12v power is pretty easy to find particularly since you only have to probe the fuses with everything off. Thank you in advance for what has worked for you for your dashcam or radar detector power needs.
I don't know but reminds me I need to get an antitheft device installed. The IGLA I guess. (wow zero installers for those around here even within a few hundred miles)
