Engine Failure
Add me to the list, I'm not sure if there's an official thread for us to gather so this was the first I found. Manual CT5, '22 with 19k on the odo, did proper break-in with service. I was driving the car last week and noticed performance was off under heavy accel in 2nd and 3rd gear. Turned all the TC settings off and tried again, engine was revving up but wheels weren't spinning. No codes and was running "fine" just cruising around town but dealer came and picked it up from my house last Friday. They ran a compression test on it yesterday and decided new engine + supercharger were required. No idea on how long it'll take yet at this stage but figured I'd share my experience.
Wow! So sorry to hear and after 19k miles!
Well, all manufacturers have issues don’t you know. 🤷‍♂️
On a much more serious note, it would be wise to have a lemon law lawyer on speed dial.
Ugh, sickening!
What is your build date? Sorry, that sucks!
I updated the Blown Motor Registry
  • Like
Reactions: TFG
While this video discusses the break-in for the LT6, I suspect the same principles apply to other GM high-performance engines.
According to the GM engineers, the initial 500-mile break-in is to uniformly polish the surface of the bearings.
Gm engineers also say to run Mobil 1 which has been tested over and over to have lower viscosity than any other 5w30 in the lf4 which already have low oil pressure issues at idle/low rpm.
Gm engineers tell 5.3 owners to run 0w20 oil
Gm engineers created the ecu software so the cars rev to the sky on startup when the bearings are dry (even worse with water oil) so the cats warm quicker.
A lot of their decisions are based on political nonsense (cafe, carb ect)
I personally break any new car in my household extremely hard. Progressive boost up to max boost within the first 100 miles + tons of vacuum…. Change the oil and it’s broken in. I build motors, tune cars. This is what i do after years of experience and talking with my machine guys. Do whatever you think works better…..
If they did a compression test and said it’s toast, that would most likely mean damage via detonation (cracked piston ring land). That’s odd as most of these failures are Rod bearings
I personally like your break-in process because it seems to line up with my logic. Additionally, thanks for the commentary re:compression. Admittedly, I'm not mechanical guy so I wasn't exactly sure what that type of test would produce. I've been in the dark all week from the dealership, I'm hoping they have some more info for me this week. Side note, I bought my first American SUV a few months before I received the Blackwing and we went through an eerily similar process whereas we had ended up with 2 blown engines on her 22' Chevy Tahoe(both ~20k mi) and after the second one we went through the GM buy-back program. I am wondering if that's what I'll choose to do with this situation as well.
I have no argument for your opinion and expertise, but if your motor blows, GM could and probably would deny warranty.
Everyone talking about engine break in should watch this...
That's one of the savage geese guys, yes? It was a good, rational, probably accurate explanation.
I just wish more people could write. I'd rather read a concise, logical paper than listen/watch a podcast or video. People just ramble and repeat themselves so much.
General comment. Not a criticism.
yea its the geese. they are pretty plugged in with OEM engineers
Ads for static web pages don't pay enough to produce even brain-dead listicles anymore let alone a piece that would have taken as much time as the script for this video did. The only way content creators can make any decent money is to turn it into a video and hope to turn a profit in the first 48-72 hours. After that the algorithm moves on.
If you REALLY just want to read, then open up the video and check out the auto-generated transcript. They're good enough you'll get the gist and not have to sit through a 12-20 minute video.
Hi Folks- So, I'm looking to buy a preowned CT5-V BW 2022-2024 and am just finding out about these catastrophic engine failures! Whats the best advice? Known history and an extended warranty?
Powertrain gets a 6-year/70,000-mile warranty but beyond that I would absolutely be looking at extended warranty or holding aside $30K to self-insure the engine. Based on the tracker I've been running here it does seem like the failure manifests early for most engines so you might be better off with a higher mile example.
Reading about all this stuff makes me glad I spent the extra grand to make it 10/100k bumper to bumper! (Though hopefully the ‘25 CT5BWs don’t run into the same issues! 🤞🏽)
Thanks @NorCal Blackwing
How many are on your tracker now? Are there any other sources to get a sense of how widespread the failure is?
13 on the tracker across all model years. It's not really a scientific sample just whoever posts about it here, plus the one from Car&Driver.
For context a rough google search shows 1,763 CT5V Blackwings were produced in MY2022 and there are 4 MY2022 failures on the tracker.
Huh......you don't say. My damn Toyota has over 100 times the mileage without a single powertrain issue, 389,000 to be more precise.
Seriously though, this doesn't instill a lot of confidence now does it.....
The Goat Rodeo is coming back to haunt!!
Our Lexus RX350's engine just blew up with only 77k miles. Religious oil changes done every 5k miles. Mechanic said he's seen 2 of the same thing happen to the 3.5V6 2GR engines. So yeah, Toyota/Lexus is not impervious. But GM V8's are having a bad time right now. Wouldn't touch one at the moment.
