Ct4vbw perf mods without CEL?
zonearc0
2022 CT4-V
Im still under warranty so I want to be somewhat cautious. Im also aware some of the tuners are throwing codes. Are there any solutions to adding real power at the moment that will not risk warranty? If not, oh well, then I'll wait until after and go crazy.
You can do JB4 or full scale Global B tune via HP Tuners. Either way will not set codes.
I assume intakes are where the cold start codes begin?
Yes, exactly, unless we tune for you via HP Tuners. Here's the verbiage from our website:
Please note: DTC P1400 is an EGR related DTC that seems to set on some cold starts under certain conditions if you’re running the aftermarket intake lid. You can use the JB4 Tuner or the DTC Assassin™ to clear the code.
The best possible tuning solution for this intake lid is our Tapout Remote Tune. With proper ECM tuning, you will retain excellent idle and drivability, maximize your power gains and experience no Check Engine light.
