2016 - 2017 Cadillac CTS-V: Service Bulletin: #PIP5179C: Extended Crank Cold With DI Engines
Administrator
Staff member
New Hampshire
Not Yet!
[h=2]#PIP5179C: Extended Crank Cold With DI (Direct Injected) Engines - (Apr 5, 2017)[/h]
Subject:* Extended Crank Cold With DI (Direct Injected) Engines
Models:*2016–2017 Chevrolet Camaro*
2016–2017 Cadillac CTS-V
2015-2017 Cadillac Escalade
2014-2017 Chevrolet Corvette
2014-2017 Chevrolet Silverado 1500 Suburban, Tahoe
2014-2017 GMC Sierra 1500 Yukon
with engines 4.3L, 5.3L, 6.2L RPO's LV3, L83, L86, LT1, LT4
<tbody>
</tbody>
This PI was superseded to update Model Years. Please discard PIP5179B.
The following diagnosis might be helpful if the vehicle exhibits the symptom(s) described in this PI.
<dl>
<dt>Condition/Concern</dt>
<dd>
DI (Direct Injected) Engines with concerns of extended or long crank time during cold ambient airtemps
</dd></dl> <dl>
<dt>Recommendation/Instructions</dt>
<dd>
Direct Injection engines may have slightly longer cold crank times than that of port fuel engines.
Direct Injection systems run at higher pressures, and the mechanical pump on the engine must buildup the required pressure before the first injection event occurs.
The below are typical Direct Injection engine crank times on GASOLINE
Start up Coolant Temperature Crank Time
Above 10° C up to 1.5 sec
Between 10°c (50F) and (- 10°c 14F) up to 2.5 sec
Between (-10°c 14F) and (-20°c -4F) up to 3.5 sec
Between (-20°c -4F) and (-25°c -13F) up to 5 sec
Between (-25°c -13F) and (-30°c -22F) up to 7 sec
Below -30 deg. C -22F, the recommendation is to perform an assisted start (such as use of a blockheater).
Note: For ETHANOL fuel see #PIP5174: Extended Engine Crank Times When Using E85
Please follow this diagnostic or repair process thoroughly and complete each step. If the condition exhibited is resolved without completing every step, the remaining steps do not need to be performed.
</dd></dl>
