A little more boost with the stock global ecm
2019V
Land O Lakes Florida
2019 CTS-V
Has anyone tried adding a little more boost either with a slightly smaller blower pulley or changing the balancer to see if the global will learn it ?
Do you think there is enough fuel for a 9.17 lower??
Well here we go, before and after pics...
Specs on the pulley and any performance gains?
Haven't installed the blower yet, I kept the stock size (2.5) because I wanted to see the gain from ported blower only. Sometime in the future I will play with different pulley sizes...
Installed the Kong X ported blower and the Tony Mamo ported 95mm ZR1 throttle body yesterday. Also swapped the spark plugs to Brisk and removed the sound plates from the lid. Best base line was 599 - 595, third pull after the swap was 669 - 576 so lost about 19 on the torque side but gained 70 on the hp side. The car is definitely more responsive & quicker around town even with the 19 lb torque loss and flat out nasty at full throttle. Also went front 10 psi to 12 psi with the stock pulley size.
Definitely more blower whine after the swap as well. Sorry for the poor video quality it was sent from my phone.
  • 20230901_105748.mp4
    215.5 KB
  • 20230905_142153.mp4
    172.9 KB
You can run the 2.3 without a tune, a 2.175 will be too much for the ECU to compensate for without a tune.
Any of you guys had to do any kind of fueling with just those mods?
