<?xml version="1.0"?>
<rss version="2.0">
<channel>
<link>https://www.cadillacvnet.com/knowledge-base/article/2013-2019-cadillac-ats-v-and-cts-v-service-bulletin-pic6364b-power-windows-may-become-inoperative-after-dead-or-discharged-battery-jan-19-2021-48.html</link>
									<div><item>
									</item>
<item>
										<guid>https://www.cadillacvnet.com/knowledge-base/article/2016-cadillac-ats-v-gm-techlink-vehicle-time-out-for-parasitic-draw-testing-4.html</guid>
										<title>2016 Cadillac ATS-V: GM TechLink:  Vehicle Time Out for Parasitic Draw Testing</title>
										<link>https://www.cadillacvnet.com/knowledge-base/article/2016-cadillac-ats-v-gm-techlink-vehicle-time-out-for-parasitic-draw-testing-4.html</link>
									</item>
<item>
									</item>
<item>
										<guid>https://www.cadillacvnet.com/knowledge-base/article/2015-2017-cadillac-ats-v-and-cts-v-gm-techlink-wireless-charging-device-compatibility-and-testing-3.html</guid>
										<title>2015 - 2017 Cadillac ATS-V and CTS-V: GM TechLink: Wireless Charging Device Compatibility and Testing</title>
										<link>https://www.cadillacvnet.com/knowledge-base/article/2015-2017-cadillac-ats-v-and-cts-v-gm-techlink-wireless-charging-device-compatibility-and-testing-3.html</link>
									</item>
<item>
										<guid>https://www.cadillacvnet.com/knowledge-base/article/2018-2019-cadillac-ats-v-cts-v-service-bulletin-20-na-054-rear-view-camera-guidance-lines-dim-after-radio-replacement-or-programming-23.html</guid>
										<title>2018 - 2019 Cadillac ATS-V - CTS-V: Service Bulletin: #20-NA-054: Rear View Camera Guidance Lines Dim After Radio Replacement or Programming</title>
										<link>https://www.cadillacvnet.com/knowledge-base/article/2018-2019-cadillac-ats-v-cts-v-service-bulletin-20-na-054-rear-view-camera-guidance-lines-dim-after-radio-replacement-or-programming-23.html</link>
									</item>
<item>
										<guid>https://www.cadillacvnet.com/knowledge-base/article/2009-2015-cadillac-cts-v-gm-techlink-poor-ground-connection-at-g110-25.html</guid>
										<title>2009 - 2015 Cadillac CTS-V: GM TechLink: Poor Ground Connection at G110</title>
										<link>https://www.cadillacvnet.com/knowledge-base/article/2009-2015-cadillac-cts-v-gm-techlink-poor-ground-connection-at-g110-25.html</link>
									</item>
</div>
								</div>
</channel>
</rss>
