<?xml version="1.0"?>
<rss version="2.0">
<channel>
<link>https://www.cadillacvnet.com/knowledge-base/article/2019-2020-cadillac-ct6-v-service-bulletin-19-na-275-moan-type-noise-heard-during-low-speed-maneuvers-sep-29-2020-35.html</link>
									<div><item>
										<guid>https://www.cadillacvnet.com/knowledge-base/article/2020-cadillac-ct5-v-service-bulletin-n202312960-service-update-differential-control-module-startup-delay-nov-12-2020-42.html</guid>
										<title>2020 Cadillac CT5-V: Service Bulletin: #N202312960: Service Update - Differential Control Module Startup Delay - (Nov 12, 2020)</title>
										<link>https://www.cadillacvnet.com/knowledge-base/article/2020-cadillac-ct5-v-service-bulletin-n202312960-service-update-differential-control-module-startup-delay-nov-12-2020-42.html</link>
									</item>
<item>
										<guid>https://www.cadillacvnet.com/knowledge-base/article/2022-cadillac-ct5-v-n212346870-service-update-front-brake-rotors-improperly-installed-sep-13-2021-67.html</guid>
										<title>2022 Cadillac CT5-V: #N212346870: Service Update - Front Brake Rotors Improperly Installed - (Sep 13, 2021)</title>
										<link>https://www.cadillacvnet.com/knowledge-base/article/2022-cadillac-ct5-v-n212346870-service-update-front-brake-rotors-improperly-installed-sep-13-2021-67.html</link>
									</item>
</div>
								</div>
</channel>
</rss>
