<?xml version="1.0"?>
<rss version="2.0">
<channel>
									<div><item>
										<guid>https://www.cadillacvnet.com/knowledge-base/article/2016-2017-cadillac-cts-v-gm-techlink-harsh-shift-and-rough-idle-conditions-28.html</guid>
										<title>2016 - 2017 Cadillac CTS-V: GM TechLink: Harsh Shift and Rough Idle Conditions</title>
										<link>https://www.cadillacvnet.com/knowledge-base/article/2016-2017-cadillac-cts-v-gm-techlink-harsh-shift-and-rough-idle-conditions-28.html</link>
									</item>
<item>
									</item>
<item>
									</item>
<item>
									</item>
<item>
									</item>
<item>
									</item>
<item>
									</item>
<item>
									</item>
<item>
									</item>
<item>
									</item>
</div>
								</div>
</channel>
</rss>
