<?xml version="1.0"?>
<rss version="2.0">
<channel>
<link>https://www.cadillacvnet.com/knowledge-base/article/2018-2019-cadillac-ats-v-cts-v-service-bulletin-20-na-054-rear-view-camera-guidance-lines-dim-after-radio-replacement-or-programming-23.html</link>
									<div><item>
									</item>
<item>
										<guid>https://www.cadillacvnet.com/knowledge-base/article/2015-2017-cadillac-ats-v-and-cts-v-gm-techlink-wireless-charging-device-compatibility-and-testing-3.html</guid>
										<title>2015 - 2017 Cadillac ATS-V and CTS-V: GM TechLink: Wireless Charging Device Compatibility and Testing</title>
										<link>https://www.cadillacvnet.com/knowledge-base/article/2015-2017-cadillac-ats-v-and-cts-v-gm-techlink-wireless-charging-device-compatibility-and-testing-3.html</link>
									</item>
<item>
									</item>
<item>
										<guid>https://www.cadillacvnet.com/knowledge-base/article/2013-2019-cadillac-ats-v-and-cts-v-service-bulletin-pic6364b-power-windows-may-become-inoperative-after-dead-or-discharged-battery-jan-19-2021-48.html</guid>
										<title>2013 - 2019 Cadillac ATS-V and CTS-V: Service Bulletin: #PIC6364B: Power Windows May Become Inoperative after Dead or Discharged Battery - (Jan 19, 2021)</title>
										<link>https://www.cadillacvnet.com/knowledge-base/article/2013-2019-cadillac-ats-v-and-cts-v-service-bulletin-pic6364b-power-windows-may-become-inoperative-after-dead-or-discharged-battery-jan-19-2021-48.html</link>
									</item>
</div>
								</div>
</channel>
</rss>
