<?xml version="1.0"?>
<rss version="2.0">
<channel>
<title>Home - All Categories - Cadillac CTS-V - 3rd Generation &amp;#x28;2016 - 2019&amp;#x29;  - Clutch and Transmission  </title>
<link>https://www.cadillacvnet.com/knowledge-base/category/cadillac-cts-v-3rd-generation-x28%3b2016-2019-x29%3b/clutch-and-transmission/23/</link>
<description>This RSS Feed contains Articles of Category in the knowledge base. You can click on the title to view its content. Powered by PHPKB (https://www.phpkb.com)</description>
<item>
										<guid>https://www.cadillacvnet.com/knowledge-base/article/2016-2021-cadillac-ats-v-cts-v-ct4-v-service-bulletin-18-na-285-information-on-slight-movement-in-park-at-ignition-on-and-vehicle-start-up-and-or-during-a-remote-vehicle-start-event-jan-22-2021-50.html</guid>
										<title>2016 - 2021 Cadillac ATS-V -CTS-V - CT4-V: Service Bulletin: #18-NA-285: Information on Slight Movement in Park at Ignition On and Vehicle Start Up and/or During a Remote Vehicle Start Event - (Jan 22, 2021)</title>
										<link>https://www.cadillacvnet.com/knowledge-base/article/2016-2021-cadillac-ats-v-cts-v-ct4-v-service-bulletin-18-na-285-information-on-slight-movement-in-park-at-ignition-on-and-vehicle-start-up-and-or-during-a-remote-vehicle-start-event-jan-22-2021-50.html</link>
										<description><![CDATA[#18-NA-285: Information on Slight Movement in Park at Ignition On and Vehicle Start Up and/or During a Remote Vehicle Start Event - (Jan 22, 2021)    Subject:&nbsp; Information on Slight Movement in Park at Ignition On and Vehicle Start Up and/or...]]></description>
									</item>
<item>
										<description><![CDATA[2015 - 2018 Cadillac CTS-V: Hard Shifting into 1st Gear or Reverse GM TechLinkJune 10, 2017 Hard shifting conditions when shifting into 1st gear or Reverse may be found on some 2014 - 2018 Silverado, Sierra and Corvette models equipped the 4.3L V6...]]></description>
									</item>
<item>
										<guid>https://www.cadillacvnet.com/knowledge-base/article/2015-2017-cadillac-ats-v-cts-v-service-bulletin-16-na-175-shake-and-or-shudder-during-light-throttle-acceleration-between-25-and-80-mph-40-and-128-km-h-at-a-steady-state-30.html</guid>
										<title>2015 - 2017 Cadillac ATS-V - CTS-V:  Service Bulletin: #16-NA-175: Shake and/or Shudder During Light Throttle Acceleration Between 25 and 80 MPH (40 and 128 KM/H) at a Steady State</title>
										<link>https://www.cadillacvnet.com/knowledge-base/article/2015-2017-cadillac-ats-v-cts-v-service-bulletin-16-na-175-shake-and-or-shudder-during-light-throttle-acceleration-between-25-and-80-mph-40-and-128-km-h-at-a-steady-state-30.html</link>
										<description><![CDATA[#16-NA-175: Shake and/or Shudder During Light Throttle Acceleration Between 25 and 80 MPH (40 and 128 KM/H) at a Steady State - (Oct 4, 2017)    Subject:&nbsp; Shake and/or Shudder During Light Throttle Acceleration Between 40 and 128 KM/H (25 and 80...]]></description>
									</item>
<item>
										<guid>https://www.cadillacvnet.com/knowledge-base/article/2014-2019-cadillac-ats-v-ct4-v-cts-v-service-bulletin-pip5784-8l45-8l90-automatic-transmissions-with-no-movement-after-valve-body-replacement-mar-1-2021-55.html</guid>
										<title>2014 - 2019 Cadillac ATS-V CT4-V CTS-V: Service Bulletin: #PIP5784: 8L45 8L90 Automatic Transmissions With No Movement After Valve Body Replacement - (Mar 1, 2021)</title>
										<link>https://www.cadillacvnet.com/knowledge-base/article/2014-2019-cadillac-ats-v-ct4-v-cts-v-service-bulletin-pip5784-8l45-8l90-automatic-transmissions-with-no-movement-after-valve-body-replacement-mar-1-2021-55.html</link>
										<description><![CDATA[#PIP5784: 8L45 8L90 Automatic Transmissions With No Movement After Valve Body Replacement - (Mar 1, 2021)     Brand:   Model:   Model Year:   VIN:   Engine:   Transmission:     from   to   from   to       Cadillac   ATS Models   2016   2019   All  ...]]></description>
									</item>
</channel>
</rss>
