Mr. Blkout, my comments are directed at the topic of discussion, not you, so please don't take offense.
For the 4BW, the OEM oil is 5w30 with a revised recommendation to use 5w40.
The 0w is for EXTREMELY cold environments, like -20 degree Minnesota winter mornings. The 0w number only relates to your cold start. The 0w number has nothing to do with tracking a car. For track use it's the second number you raise, not the first one, so you'd want a 5w50, or a 10w50 for the track if going further than the revised 5w40.
There is no reason, no benefit to using 0w40 versus 5w40 oil and there is actually a detriment. The wider the gap between the 2 numbers the faster your second number shears down to a lower protection level. 5w40 absolutely is better for the 5BW than 0w40, unless it's extremely cold.
Granted this thread was about the 5BW, not the 4BW, but the fundamental principles of oil remain the same.
GM gives the 0w40 recommendation knowing some cars live in Alaska and some live in Arizona. A car that lives in Arizona would be better off not using the 0w40. One last time, there is a very specific reason for the 0w number and that reason simply does not exist in Arizona or any other hot climate.
