jonnywaffles11
I lasted 6 months before prying panels off so I'll count that as a win. ever since seeing the larger screen in the 5, I have been annoyed at the small display in the CT4. I drunkenly ended up buying some pulled displays from wrecked cars off eBay and decided to see if I could do a swap. The screen is definitely larger and fills the space more. I will need to figure out a few mounts which won't be too hard. The big hangup is that while the connectors are identical and everything plugged right in, the display itself is tiled and not outputting the signal to scale. The digitizer is detecting touch inputs according to where they should be for the size screen so its purely a video output issue which should be easier to troublshoot. I'll welcome any advice on this from more electrical engineering minded people. If I can get that to output right, I will likely be doing a carbon fiber surround since everything will need to be custom sized to the smaller opening of the 4 vs the 5.
