Replacing 6 x 9's
TheGBKid
South Carolina
Hi,
I'm in the process of a significant audio upgrade on our 23 5BW. I can't seem to find any diagrams/instructions on how to remove the rear deck so I can access the 6 x 9 speakers and sound deaden that entire panel. Has anybody else done this and can provide guidance? Appreciate the help.
Gary
I had to just do this for the belts I swapped to. You have to take both c pillars out. Fold the seats down and there are like six plastic fasteners that you have to take out. Push upon the deck lid and then slide it out towards the front of the car.
I didn't take any pics during the install sorry. Hopefully these will help. You need to remove these panels on both sides. There's one bolt behind the airbag cover that you need to remove. That seatbelt cover comes out pretty easy. Just use a small screw driver.
The panels are just held in by clips. They pop out pretty easy. Then you need to remove these plastic push fasteners.
Once all the is done. Push up on the deck lid then slide it forward.
Absolutely fantastic! I saw the 4 push pins and have those removed - couldn't figure out how the others were attached. You solved it. Owe you a beer some day.
Sure did! All because of your help. Would've NEVER found the bolts under the air bag cap. Thank you again
Hey but give us some details on your upgrades!
Glad to provide some details now that it is sounding WAY better:
Added HELIX V EIGHT DSP MK2 for front stage (powering Blam 6x9 components and 80mm drivers in doors/ A pillars)
Added Helix 600w Mono amp and that's powering JL-Audio-HO112-W6v3
Removed the 6x9's in the rear deck and sound deadened inside doors/ rear deck, full trunk.
SQ is phenomenal, plenty of bass to shake my baseball cap, but not so much that it can be heard a block away. DSP's are a complete game changer from when I was using EQ's on Rockford Fosgate installs in the mid-late 90's. So much more control and precision around delays, cut-offs etc.
Gonna let this sit for awhile to determine if there are any other changes I'd like to make. Only possibility is changing to a custom ported enclosure for the 12" sub that will port through the openings left by the removal of the 6x9's, but that isn't a project I want to take on in 95 degree heat in SC.
