Range AFM Unit
Daniel Goss
East Texas
2025 CT5V Blackwing
New owner and member here. For decades my "fun" cars have been Corvettes. But at 77 yrs old and bad knees, it has become too much of a chore to simply get in and out of my current 2019 Z06, so yesterday I made a trade deal and today I will be taking home a new 2025 CT5 Blackwing. In my Corvette I have been leaving a Range device plugged in, as I just don't like cylinder deactivation, or AFM. Does the Blackwing also have some type of cylinder deactivation, and if so, are any of you preventing the engine from going into 4 cylinder mode? Range Technology does not make a plug in unit for the Blackwing, and I am not interested in doing an aftermarket tune, so what options are any of you using?
The LT4 in the BW does not have AFM/DFM. No Range needed (I have one in my L87 6.2).
I appreciate the quick response. That is good news. I should have mentioned that my BW is an auto transmission, so it really has no AFM type system? That surprises me, but I like the idea.
My 2022 5BW with auto has AFM. It only comes on when in Tour mode and generally only while coasting with little to no throttle. I believe the 2023-2026 5BW autos continue to have AFM as well. See my original post on this
AFM? (thread here)
Since I rarely drive in Tour mode, it's hardly ever on for me.
AFM? (thread here)
Interesting, i stand corrected. I have a MT so perhaps AFM was included in the auto but AFM wasn't included in the manuals?
Then again, there isn't a V8/V4 visual indicator (in the MT) that I'm aware of nor an audible change like I noticed with my 21' Suburban 6.2.
Correct. No AFM in cars with MT nor is there a V8 dash indicator of any sort like you see in photo of my original post.
With the 5BW, AFM (cylinder deactivation) is on the automatics only. There is a dash light in green that will show V4 when the cylinders are deactivated. Usually, the only time I see it is when using cruise control. Any slightly spirited driving will eliminate the use of AFM.
I know I have read manuals have the hardware in the engines, but it does not function. Not sure if that is accurate or not.
Yes, it's accurate. The ECM controls when a circuit board shuts down 4 cylinders via solenoid during low load conditions. All of the LT4s are supposedly the same but the ECM in the MT never triggers the shutdown.
A couple of informative videos on how the system works.
Hi all,
Well I was a bit surprised that I didn’t think about AFM when I bought the ‘26 BW auto. In all honesty I have been gently going through the 1500 mile break in, and never noticed any AFM engagement. But from what I’ve read, my ‘26 does have the AFM.
I think I’m going to order the plug in module to bypass the AFM. I love the LT4 and I never thought about AFM as an issue with my prior Camaro ZLE’s (6M’s). But I do not like the idea of having the AFM on this car. It makes me feel like I’m driving an economy car rather than a legit performance 4-dr sedan.
I don’t want to take the motor apart and change cam/lifters and whatever else, at least until I have to for another reason.
Has anyone here used and had any issues with the plug in AFM eliminators??
TIA,
JJ
Hi all,
TIA,
JJ
The auto start doesn't save any meaningful amount of fuel. It's a stupid, corrupt regulation that is thankfully dead
Hi all,
TIA,
JJ
I had the range unit in my 2017 CTSV and it worked flawlessly.
Hi all,
TIA,
JJ
Assuming the dash shows the V4/V8 indicator, see how often it actually drops into V4 mode. On my A8 C7 Z06, it rarely activates, and it's not noticeable when it does. IIRC, the main side affects were battery drain but I think those issues were improved on later iterations of the Range device. There is probably a lot more info available on Corvette forums.
