QQ: what's latest status on magnesium wheels?!?
Doesn't look promising. They may not have enough magnesium to produce aluminum parts soon.
That article may be true but I doubt caddy would advertise wheels they don't have
Back in 2015 Cadillac was talking about a Carbon Ceramic Brake option on the 3rd generation CTSV and it didn’t make it into production , so you never know what might happen .
We're they? I only remember when the chief engineer was debuting the V3 and said the steel brakes have come a long way in fade prevention and that was why they didn't offer it.
A friend somehow lucked into a set. I’m trying to get him to weight them and to see if they have a part number.
Bet that's in Kg, because the front tire all by itself is 28lbs and the rear is 30lbs.
If all this is true, then these aren't actually very light. 26.4kg = 58lbs. If the tire is 28lbs then that's a 30lb front wheel? Rather heavy. I recall the standard wheels are 29lbs front and bronze is a little heavier. So the mag ones might be a tiny bit lighter than the same bronze wheel design in aluminum, but not a big difference and no lighter than the standard polished or dark gray wheels.
It looks like ~10lbs lighter for a rear as I believe this was without TPMS. Substantial enough to require a mag ride recalibration if put into production?
GM's supply chain issues turned into a win for them. They can charge for an upgraded wheel without it actually being Magnesium as originally promised.
