ShiftToSixth
I noticed my eLSD, even at a stop, not moving, was at 3% today. It never went below that percentage.
Anyone have similar results while at a stop?
some info on the system courtesy of @LF4472.Re: eLSD, Electronic Limited Slip Differential DIC Screens – TechLink is a good reading for that system and the gauge.
I read that article, but when the car isn't even in gear, at a full stop, why would it read 3%. That doesn't make sense to me.some info on the system courtesy of @LF4472.
That is my assumption (it never goes fully open). The percentage is only a measure of open vs closed so it doesn't seem wrong to show 3% even if the car is not moving/not in gear.My 5BW is at 3% at a stop, but never gave it much thought, 3% is close enough to zero for me. Maybe the 3% is just to let the user know that the system is working? Maybe it never really behaves like a true open diff?
This. It's an electronic "limited" slip differential and not an open diff. Going purely off the semantics i'd assume the same as above that it never de-couples completely. I'm sure engineering an open to limited to closed electronically controlled diff would be a nightmare.That is my assumption (it never goes fully open). The percentage is only a measure of open vs closed so it doesn't seem wrong to show 3% even if the car is not moving/not in gear.
Good call lol. I should have checked there first. ThanksApparently, the manual is the last place to look, LOL!
Page 120:
For the V-Blackwing models, the eLSD
maintains some coupling even if the
vehicle is stationary or not
accelerating. Coupling values of 3%
and up are typical.
LOL, sometimes obscure stuff does show up there. 🙂Good call lol. I should have checked there first. Thanks
