CT4-Villain
Ok thanksUnder "Apllication *", you can select CT4-V BW for an additional $12.
The open breather helps vent crankcase pressure.Also curious, is there any kind of benefit to having an open breather catch can vs closed?
Was thinking about getting the throttle body, how do you like it? One of those things where the instructions look like 500 things that need to be removed, but says 30-60 minutes to install. Is it worth the time to do it? Any issues with idle or needing to do the relearning that the instructions say on it? I'm keeping mine stock, but if the throttle body can do 10-15whp might be worth it.Trust me, you want it. When I installed my throttle body there was oil around the intercooler bricks in a couple areas.
It’s totally plug and play. No learning. I had absolutely zero problems. There are a lot of vacuum lines to remove to get that vacuum box off the top but it’s not that bad. I would recommend changing your plugs at this time since you have easy accessWas thinking about getting the throttle body, how do you like it? One of those things where the instructions look like 500 things that need to be removed, but says 30-60 minutes to install. Is it worth the time to do it? Any issues with idle or needing to do the relearning that the instructions say on it? I'm keeping mine stock, but if the throttle body can do 10-15whp might be worth it.
lol yeah I was looking at the instructions and it's just like, ok well that's about 50 vacuum hoses and 100 screws to go wrong somewhere....It’s totally plug and play. No learning. I had absolutely zero problems. There are a lot of vacuum lines to remove to get that vacuum box off the top but it’s not that bad. I would recommend changing your plugs at this time since you have easy access![]()
I had an issue with rpm flutter at low rpms. That lasted about 50 miles and then it went back to normal, no relearn needed. Install was easy, hardest part was making sure you connect all the vacuum lines.Was thinking about getting the throttle body, how do you like it? One of those things where the instructions look like 500 things that need to be removed, but says 30-60 minutes to install. Is it worth the time to do it? Any issues with idle or needing to do the relearning that the instructions say on it? I'm keeping mine stock, but if the throttle body can do 10-15whp might be worth it.
