CTV4 6sp clutch
CaliBW
Upland
2026 CTV-4 BW
Hello fellow BW owners. Lots of posts about clutches etc but my question doesn't seem to be addressed.
Mine has 1200 miles and I love this car!! Is it normal to be stiff going into first and a bit clunky going into second? 3-4, 4-5, 5-6 are all good.
Also being an OG with OG stick shift history how does one know if the clutch is adjusted correctly.
I want these thoughts put to rest by 1500 miles so when I do the first NLS I want to know the car is 100% ready. Maybe a few burnouts too!! I will change the rear end lube and do the first oil prior to also.
If there is a thread covering all this just point me there, thanks
I've owned 5 Tremec 6 speeds. Three C6 Vettes, a 2005 Chevy SSR, and now a new CT5 Blackwing. I have experienced none of what you're describing in any of them. All smooth as butter from 1st on up. Never felt the urge to change any of the shifters either.
I'd say take it back to the dealer with your complaints to get your complaint on record. They will probably tell you to put a few thousand miles on it and see if the conditions disappear. That's probably bullshit. It ought to be good from the get-go.
Second gear notchiness or worse is common on this transmission. This history goes back to the begining of this tranny and even its predecessor. I have had it in my atsv and I have seen numerous people had the transmission replaced ed when it was bad enough.
will do, thanks
thanks!
There has be at least 100 posts about notchy 2nd gear on this forum, supper common. This is more typical when the fluid is cold, particularly in winter. If it's always notchy and difficult, then you might have an issue, but otherwise I'd consider it "normal". Being a hydraulic clutch there is no adjustment.
thanks, i put numerous words in the search with little luck
This is probably the most comprehensive, and newest.
very detailed, thanks for the link!!
