CT4 Blackwing at Sonoma
Sebring20
Bay Area
CT4V Blackwing
Let's pick up some activity in this section! Took my CT4 to Sonoma this weekend, lots of fun. Love the car and PDR.
Found the OE tires get greasy after a couple hot laps, I would have to do a couple fast laps, cool down, then go again. Only thing I'm still trying to get used to is the e boost brake system, I find it hard to modulate the brakes still.
Any one run different tires/sizes for track other than OEM? Thinking about V730. Also would love to hear if you are running different pads as well, though I find the stock ones are adequate so far (lots of dust)
Enjoy!
Also I'm pretty sure I saw this somewhere but can't seem to find it again...
If we select PTM mode (say RACE 1), that adjusts all the other parameters to Track mode correct? We don't have to manually go into Track, then RACE 1.
PTM is only avail in Track Mode. If you are using the rocker switch on the steering wheel to adjust PTM modes, you are automatically switching the drive mode to Track.
Wow, I think I might feel lost with all that space everywhere. Here's July 4th at Watkins Glen. Look how tight things look compared to Sonoma. I'm running Porterfield brakes, which have really increased the stopping power and pushed back braking points. 2.7 front and 1.7 camber. I'm guessing you haven't done camber yet?
I watched this again and damn you are really pushing it. 1.6g in turn 3 - wow!
Yep I've done the camber, I think similar specs to what you have, maybe a little more (shop maxed it out). WG is super tight! Just tracked laguna seca this weekend, will post videos shortly
Thanks!
Just noticed you're not in PTM modes and TC is coming on. Found that PTM definitely helps on track
Have you done brake pads yet? Go with a full race on front(non-street) and an aggressive street pad for the back. They make a big difference when trying to push back your braking points. Supposedly your not supposed to use race pads on the street, but I'm finding them to be fine for daily driving.
Have you installed the front brake cooling duct kit that came with the car? I recently learned there is also a rear brake cooling duct kit that doesn't come with the car. I got it from WildHammer for $75.
I'll have new video next week. Driving Monticello in NY Monday.
Nope, car is all stock. Havent got around to tweaking it yet. I think for CT4 only rear brake duckts come stock. I havent found the need yet
