Belt shreded
Jakemey
Fl
2022 ct5-v blackwing
2022 Ct5v BW : Was driving yesterday, heard a sound i could describe as driving drown a dirt road, little ticks hitting the bottom of the car then battery light went on and car was starting to overheat, pulled over and my cooling belt was shredded , i was entering the highway doing about 45 put it in v mode , didn’t step on it i was accelerating normally when it happened. When i pulled over i saw that coolant was also leaking from the undercarriage passenger side I’m assuming just from the over flow because the car was overheating, has anyone had any issue like this??
Side note: when i looked under the car at the coolant leak i noticed the shear plate was shredded at the jack point on both passenger and driver side not sure if it’s from previous owner , it was a old gentleman who had it i have attached pictures let me know if anyone has seen anything like this as well
This is my first time posting on this forum I’m not sure if I’m doing this right let me know lol
  • IMG_2516.mov
    15.7 MB
I’m thinking possibly maybe someone used a lift wrong and had somthing get stuck idk lol
GM certified Tech! Gotta love it!
Thankfully, I haven't had any issues so far, and I hope you get your results ASAP with as least amount of frustration as possible. I'm glad you pulled over and timely manner and looked into it in a detailed fashion.
Good luck and please keep us posted.
Update they finally looked at it and said that the alternator seized up and caused the belt to snap and they are trying to figure out why
Welp here we are again the car turned off while i was driving yesterday costed off to the side and couldn’t crank back up , burned up the starter wire and had to get it towed; thinking the alternator is fried again lol 3 months of ownership and have been left on the side of the road 2 times already
It appears you have some bad voodoo following you my friend. Maybe you need to get some cigars, rum, and fried chicken for Jobu. :)
UPDATE 8/18/2025 engine is blown, said the bottom end and have to replace it
