Sticking with Mobil 1 brand oils.
I've considered Motul or Liqui Moly, but trying to stay in the realm of OEM and more importantly, more affordable oils, although Dexos R oils aren't exactly cheap.
I ran Motul 5w40 8100 in the 1LE. That would be a good 5w40.
Going to a 0w-X won't hurt anything other than provide better flow at startup going to a 10w-X wouldn't be ideal.
I wouldn't run 10w40 in the winter with 0 temps, but I'd consider it during the summer months when the ambient temp is never below 60 degrees.
With the wholesale contact I've provided, the Motul is the same price as Dexros R.
I called Motul and spoke with them. I told them my car, what I was doing with it and that I did not want to discuss price. The only variable I wanted to know about is what is the VERY best oil you make for my application. I was told the 300V is their best oil.
As for Motul 8100 versus the 300V, the 8100 is their street car oil, while the 300V is their race car oil. Here's an AI answer on the topic.
Neither is objectively "better" overall; it depends strictly on your usage.
Motul 300V is the better racing oil for track use, extreme heat, and maximum horsepower.
Motul 8100 is a far better street and daily driving oil, offering longer service intervals and better engine cleaning additives. [
1,
2,
3,
4]
Understanding the specific differences will help you decide which fits your needs:
- Motul 300V (Racing): Uses a specialized Ester Core technology designed for competition. It provides superior shear resistance, film strength, and power output. However, because it is formulated purely for performance, it lacks the standard detergent packages found in street oils and must be changed frequently (typically every 3,000 miles or immediately after track events). [1, 2, 3, 4, 5]
- Motul 8100 (Street/Daily): Formulated for everyday passenger and sports cars. It meets strict manufacturer approvals (like BMW, Mercedes-Benz, Porsche, and VW) and features long-life additive packages designed to clean the engine and handle extended oil drain intervals (often up to 10,000+ miles, depending on your vehicle's manual). [1, 2, 3, 4, 5]
The OP's question was specifically about track use, so I stand firm on the Motul 300V. Mobil 1 simply is not in the same league as the Motul. Like not even close for track purposes.
I previously used Mobil 1 and changed my oil every 2 days. With the Motul, I've gone to 3 days between oil changes.
