2006 sts 4.6 vvt phasers
V8forme
California
2006 sts 4.6
Hello. I have a P0014 camshaft position timing issue on the exhaust side of Bank 1, specifically that the camshaft timing is over-advanced bank 1 and a P0300 code multiple miss fire.i just replaced all coils and plugs.
I replaced the cam position sensor bank 1 exhaust sensor.
Car runs rough.
I ohmed the VVT cam actuators attached to the cams on both banks.
Online it says these should ohm between 7.5 to 12 ohms
All four of mine are only coming up 4.0 on a 200 ohm setting,.
Does anyone know if the actuators
On the 4.6 should be only 4.0 ohms
Or is all four bad?
Very strange all would go bad and I only have the exhaust bank 1 throwing a code?
Any help would be appreciated
Just an update..
I took off the two cam electric magnets on outside of head in front
The exhaust and intake both had a broken vvt oil control valve. Broke at plunger. The electric magnets came of with the plunger inside them.. luckily the bank 2 driver side was ok!
Does anyone know where I can get these oil valves? Has anyone else experienced this before
