CT5-V 2024/2025 Production Statistics
TenTonTony
Big Texas
26 5BW M6 (86-403), formerly 25 5BW M6 (lemon)
Has anyone seen any information published regarding final build statistics for the 2024 and 2025 model years? It may still be a bit soon for 2025 data, but I figure GM would have released 2024 stats if they planned to.
I recall from looking at the serial numbers on units in inventory that there were somewhere around 1000+ for both MT and AT each year. Sure would be nice to get Corvette-level data so we can all talk about our 1-of-1 builds nonstop!
I read somewhere that GM doesn't really release numbers anymore. It's a shame because it really would be nice to know. They did release numbers for 2022 and possibly 2023, but I don't think anything for 2024 or later.
This site is something I just found. It seems really accurate; unless you work at GM i guess it would be hard to know.
I will admit that I hesitated to post this here as it seems too good to be true. If someone could please archive all of this today, lol. We’d have a pretty good standard to point at for 22-25 at least. If this holds until end of ‘26 production it would be perfect.
Excellent find!
The page is not without issues; for example searching for "Precision Package" (or any of the others) always results in zero results.
[edit:] I think the problem is only Corvette options have been implemented.
It appears to work perfectly for me. Check to see if you have some filters on. 437 so far in 26. 286 M6.
24 cyber yellow with 12 auto 12 manual for 2026. 88 total for the two year color run. For kicks my ZL1 manual vert it shows 6 and that was the number i came up with back at end off 22 run. Great find!
  • Like
Reactions: Z28
I just used this site on a 2026 BW that I was looking at. It appears to work perfectly as I checked it against the GM build sheet that was provided to me from the Dealer.
  • Like
Reactions: Z28
It's an awesome website. I've used it to find the window sticker of preowned Escalades, because, you know, not all dealers are knowledgeable, when I was looking to buy one....still not sure what to do about getting one.
Be sure to clear all filters before you search. Sometimes it gets confused.
This is pretty cool. It found my VIN.
I can't believe only 174 people got a Red CT5 BWs out of over 2,000 built in '23.
Apparently, though, nothing prior to 2022 is still available. That's too bad. Another title says 2020+, so is it always only about 2 or 3 years of history ?
  • Like
Reactions: Z28
The problem is that any search that includes 2025 and V8V returns no results.
  • Like
Reactions: Z28
I traded email with the developer and he fixed the 2025 vs. V8V issue. He also said he would work on flushing out the RPO codes later.
Scroll to the right. There is a column called Packages/Options. There you can select Precision Package. I missed this as well as it is not clear there are extra columns to the right. The last column is Country. So if you see that then you have reached the last column.
Hopefully the dev adds the Cadillac RPO codes to the search. I would love to be able to find out the take rates for sunroofs and the different interiors.
Yes, yes, that was exactly what I was doing. But the site was broken and returning only 2026 vehicles... I wanted to search for 2025, that plus V8V was not matching any vehicles.
Weird. Might be your browser. Try this direct link to see 2025 CT5BW with Precision Package.
It seemed to behave differently when I was using a phone vs a laptop. Laptop seemed to work better for me.
Wow.
Yes, it works now. But it was broken yesterday around (and before) 7pm pacific time. The developer said said: "I accidentally applied 2026 only to the V8V filter when I first heard of the package"
Today (I as I posted) the developer fixed a bug that was excluding the precision package from 2025 results.
It works much better today. But only after the bug was fixed.
Wow.
