Cleaning this thing is a BITCH !!!
CBH
Austin, TX
'23 CT5 Blackwing w/ Clutch
The Marquis de Saad must've designed the front end of the CT5 BW. There are a seemingly endless array of fins, ducts, angles, ridges and crevices.
It had an embarrassing number of bugs that had been there an embarrassingly long time, but 30 minutes of scrubbing with soap and water had no effect. Following that up a motorcycle cleaner/bug remover spray that usually has good results on my bikes also had little noticeable effect.
Does anybody have a secret weapon against dried-on bugs ?
PS - when I first put water on it, suds came pouring off of it. I presume residue from the last commercial car wash ? They always seem chincy with the water and seem to never rinse enough, so my fear that soap is left on the car appears to be confirmed.
The only thing I've found over the years is...first, get them off asap (warm/hot soapy water, if possible)...second, a good coat of wax/polish really helps....third, mine has PPF and really helps too.
PPF, ceramic coating and staying on top of it is my approach. You have to get them off as soon as you can, else they will start to etch the clear coat.
This is representative of what my front-end looked like after a 1300 mile drive from Ohio to Texas.
And this is how clean I got it with some water-less car wash and 20 minutes...
I am going to try Griots Bug Barricade before my next long trip. Hopefully that will make cleaning off the bugs easier.
EZ Bug Remover
RV people use this method with good results. Also heard that spraying RainX on the front will make the bugs come off easier.
I have used WD-40, it works pretty good too. Never seemed to have any bad effect on the paint. Maybe silicone spray would work too.
I have a whole detail center set up on the side of my home. I have an electric awning to keep sunshine away, portable vacuum, 2000psi Greenworks electric pressure washer, hot/cold water connection w/ foam cannon and a 75' hose attached to a 30 gallon compressor in my basement. The hot water works great for removing bugs, but ...I also had the whole front end PPF'd and ceramic coated. November will be here soon and the 5BW will go into storage until next April. Taking her on a 222 mile foliage viewing cruise up the Hudson Valley in a week, weather permitting. My 2022 should hit the 7000 mile mark around that time.
Don't let them sit for too long and it will be easier to clean up.
Absolutely. Get them off ASAP. I make sure I re-treat the front end with ceramic spray before a long trip and keep a car wash kit in the trunk. Trip planning includes noting where self service car washes are and a roll of quarters, if needed, LOL.
I have more recently become a strong proponent for the afterwash ceramic sprays. Considering the amount of time it takes to wash and dry, an extra five minutes to spray down and wipe off at the end really keeps a shine on the paint much longer. Not to mention the beading properties it offers if you're getting rained on.
I wouldn't use them for bugs, but supposedly you can use the synthetic clay towels to remove contaminants without damage to surfaces protected by ceramic coatings. But verify with the brand of towel you use.
I use the Adam's bug removal spray with my pressure washer/soft tip, everything comes off in minutes.
  • Like
Reactions: CBH
My C7 Z06 counters with even MORE vents and places to clean. My Blackwing feels simple in comparison.
about 20 years ago, I was driving about 150 miles home in the evening from a site visit. Turns out it was peak grasshopper time and I ran through all my windsheild washer fluid trying to get home. It was almost midnight and I parked in the garage and went to bed. Next morning the garage smelled so bad and the front of the car looked like a giant had sneezed boogers all over the front surfaces from all the hoppers; I had to take immediate action. I called a rancher friend and he recommended "Bug Off" from SeaFoam. I tracked it down and followed the directions. Worked a treat and the boogers melted away. This included the radiator which was coated from the stuff that made it through the grill.
BugOff is a little hard to find, but worth it.
I used that on my M4 once, and it worked great on painted surfaces but stained the plastic.
Yeah, I'm late to the party here, I've been away...
Griots also makes a bug&tar remover that I have fallen in love with. Spray, let it sit for a minute or two, wipe off. Old bugs require a little bit of scrubbing, but not much. Really works great!
Are those canards available for the CT5 BW anyone know? Also how are they attached? TIA
Not sure I agree my C7 ZO6 seems easier to keep clean with fewer nooks and crannies. Just my opinion
