Home >> Cadillac CTS Vsport Tech Center >> 2015 Cadillac CTS and CTS Vsport Sedan Specifications
Source: General Motors Media
Overview
Model: Cadillac CTS Sedan
Body style / driveline: four-door luxury sport luxury sedan, RWD/AWD
Construction: unitized welded steel body with direct-mounted front cradle and rubber-isolated, multi-link independent rear suspension
EPA vehicle class: midsize car
Manufacturing location: Lansing Grand River Assembly, Lansing, Mich.
Back to top
Engines
2.0L Turbo DI VVT 3.6L V-6 DI VVT Twin-Turbo 3.6L DI VVT
Displacement (cu in / cc): 122 / 1998 217 / 3564 217 / 3564
Bore & stroke (in / mm): 3.39 x 3.39 / 86 x 86 3.70 x 3.37 / 94 x 85.6 3.70 x 3.37 / 94 x 85.6
Block material: cast aluminum cast aluminum cast aluminum
Cylinder head material: cast aluminum cast aluminum cast aluminum
Valvetrain: DOHC, four-valves per cylinder, continuously variable valve timing DOHC, four valves per cylinder, continuously variable valve timing DOHC, four valves per cylinder, continuously variable valve timing
Fuel delivery: direct high-pressure fuel injection direct high-pressure fuel injection direct high-pressure fuel injection
Compression ratio: 9.5:1 11.5:1 10.2:1
Horsepower
(hp / kW @ rpm):
272 / 203 @ 5500
(SAE certified)
321 / 239 @ 6800
(SAE certified)
420 / 313 @ 5750 (SAE certified)
Torque
(lb-ft / Nm @ rpm):
295 / 400 @ 1700-5500 (SAE certified) 275 / 373 @ 4800 (SAE certified) 430 / 583 @ 3500-4500 (SAE certified)
Recommended fuel: premium recommended but not required regular unleaded or E85 premium required
Maximum engine speed (rpm): 7000 7200 6500
EPA-estimated fuel economy (city / hwy): 20 / 30 RWD
19 / 28 AWD
18 / 29 RWD
18 / 26 AWD
16 / 24
Back to top
Transmissions
Type: Paddle-shift six-speed, electronically controlled, automatic overdrive with torque converter clutch Paddle-shift eight-speed, electronically controlled automatic overdrive with torque converter clutch
Gear ratios (:1):
First: 4.06 4.60
Second: 2.37 2.72
Third: 1.55 1.86
Fourth: 1.16 1.46
Fifth: 0.85 1.23
Sixth: 0.67 1.00
Seventh: 0.82
Eighth: 0.69
Reverse: 3.20 4.06
Final drive ratio: 3.45 (RWD)
3.27 (AWD)
2.85
Back to top
Chassis/Suspension
Configuration: rear-wheel drive or all-wheel drive
Differential: open differential (RWD/AWD) or optional electronic limited-slip (FE3/Vsport)
Front: FE2: MacPherson-type with dual lower ball joints, twin-tube struts and direct-acting stabilizer bar or uplevel optional Magnetic Ride Control with monotube inverted struts
FE3: MacPherson-type with dual lower ball joints, direct-acting stabilizer bar and Magnetic Ride Control with monotube inverted struts
Rear: FE2: independent five-link with twin-tube shock absorbers or uplevel optional Magnetic Ride Control with monotube shocks
FE3: independent five-link with Magnetic Ride Control with monotube shocks
Steering type: ZF rack-mounted electric, power-assisted and variable assist
Steering ratio: FE2 RWD: 16.5
FE2 AWD: 16.2
FE3 RWD: 15.4
Steering turns, lock-to-lock: FE2 RWD: 2.6
FE2 AWD: 2.8
FE3 RWD: 2.5
Turn circle (ft / m): FE2 RWD: 37.1 / 11.3
FE2 AWD: 39 / 11.9
FE3 RWD: 36.7 / 11.5
Chassis control: four-channel StabiliTrak w/ brake assist and traction control
Back to top
Brakes
Type: four-wheel discs; front: 4-piston aluminum Brembo fixed calipers; rear: single-piston cast iron sliding calipers; four-channel ABS/TCS w/ DRP
Rotor type and  thickness — front (in / mm): standard: 12.6 / 321 vented, with Ferritic Nitro Carburized process for corrosion resistance; aluminum dual-piston calipers
uplevel: 13.6 / 345 vented, with Ferritic Nitro Carburized process for corrosion resistance; aluminum dual-piston calipers
Rotor type and  thickness – rear (in / mm): standard: 12.4 / 315 vented, with Ferritic Nitro Carburized process for corrosion resistance; aluminum single-piston calipers
uplevel: 12.4 / 315 vented, with Ferritic Nitro Carburized process for corrosion resistance; single-piston, cast iron sliding calipers
Back to top
Wheels/Tires
Wheel size and type: 17 x 8.5-inch aluminum
18 x 8.5-inch aluminum
18 x 9.5-inch aluminum (rear wheels on Vsport)
19 x 8.5-inch aluminum
Tire size: 245/45R17
245/40R18
275/35R18 (rear tires on Vsport)
255/35R19
Back to top
Exterior
Wheelbase (in / mm): 114.6 / 2910
Length (in / mm): 195.5 / 4966
Height (in / mm): 57.2 / 1454
Width (in / mm): 72.2 / 1833
Track (in / mm): front: 61.4 / 1560
rear: 61.7 / 1568
Base curb weight (lb / kg): 3616 / 1640 (2.0L Turbo RWD)
3772 / 1711 (2.0L Turbo AWD)
3757 / 1704 (3.6L RWD)
3889 / 1764 (3.6L AWD)
3952 / 1793 (3.6L Twin-Turbo)
Weight distribution
(% front / rear):
50 / 50
Interior
Legroom (in / mm): front: 42.6 / 1081
rear: 35.4 / 899
Headroom (in / mm): front: 39.2 / 995
rear: 37.5 / 952
Shoulder room (in / mm): front: 56.9 / 1446
rear: 54.8 / 1392
Hip room (in / mm): front: 53.8 / 1366
rear: 53.3 / 1353
Back to top
Capacities
Seating capacity
(front / rear):
2 / 3
EPA passenger volume
(cu ft / L):
97 / 2746
EPA trunk volume
(cu ft / L):
13.7 / 388
Trailer towing maximum
(lb / kg):
1000 / 454 (3.6L)
Fuel tank (gal / L): 19 / 72
Engine oil (qt / L): 2.0L Turbo: 5 / 4.7 (RWD); 6 / 5.7 (AWD)
3.6L: 6 / 5.7 (RWD & AWD)
3.6L Twin-Turbo: 7 / 6.6
Cooling system (qt / L): 2.0L Turbo: 9 / 8.5
3.6L: 11.9 / 11.3
3.6L Twin-Turbo engine: 11.9 / 11.3
3.6L Twin-Turbo charge cooler: 1.7 / 1.6
Back to top
Note: Information shown is current at time of publication.
