Home >> Cadillac ATS-V Tech Center >> 2016 Cadillac ATS-V Tech Center >> 2016 Cadillac ATS-V Preliminary Specifications
November 18, 2014
GM Media
Overview
Model: Cadillac ATS-V coupe and sedan
Body style / driveline: 2-door luxury sport luxury coupe (RWD) or 4-door sport luxury sedan (RWD)
Construction: unitized welded steel body with direct-mounted front cradle and rubber-isolated, multi-link independent rear suspension
GM vehicle class: compact luxury car
Engines
3.6L V-6 Twin-Turbocharged DI VVT
Displacement (cu in / cc): 217 / 3564
Bore & stroke (in / mm): 3.7 x 3.37 / 94 x 85.6
Block material: cast aluminum
Cylinder head material: cast aluminum
Valvetrain: DOHC, four valves per cylinder, continuously variable valve timing
Fuel delivery: direct high-pressure fuel injection
Compression ratio: 10.2:1
Horsepower
(hp / kW @ rpm):
455 / 339 @ 5750 (est.)
Torque (lb-ft / Nm @ rpm): 445 / 603 @ 3500 (est.)
Recommended fuel: premium
Max engine speed (rpm): 6500
Estimated fuel economy
(city / hwy):
TBD
Transmissions
  TREMEC TR6060 Hydra-Matic 8L90
Type: fully synchronized six-speed manual with double overdrive; active rev matching and no-lift shifting features paddle-shift eight-speed, electronically controlled, automatic overdrive with torque converter clutch
Gear ratios (:1):
First: 3.01 4.56
Second: 2.07 2.97
Third: 1.43 2.08
Fourth: 1.00 1.69
Fifth: 0.84 1.27
Sixth: 0.57 1.00
Seventh: 0.85
Eighth: 0.65
Reverse: 3.28 3.82
Final drive ratio: 3.73 2.85
Chassis/Suspension
Configuration: rear-wheel drive
Differential: electronic limited-slip
Front suspension: MacPherson-type with dual lower ball joints and direct-acting stabilizer bar; magnetic ride control with monotube inverted struts
Rear suspension: independent five-link with magnetic ride control
Steering type: ZF rack-mounted electric, power-assisted and variable assist
Steering ratio: 15.54 (on center) to 11.1 (full lock)
Steering turns, lock to lock: 2.35
Turn circle (ft / m): 38.38 / 11.7
Chassis control: four-channel StabiliTrak w/ brake assist and traction control; Performance Traction Management
Wheels/Tires
Wheel size and type: 18 x 9-inch front / 18 x 9.5-inch rear aluminum
Tire size: front: 255/35ZR18 Michelin Pilot Super Sport
rear: 275/35ZR18 Michelin Pilot Super Sport
Brakes
Type: four-wheel disc; four-channel ABS/TCS w/ DRP; Brembo brakes with staggered six-piston calipers (front) and four-piston calipers (rear)
Rotor type and  thickness
(in / mm):
front: 14.5 x 1.34 (370 x 34) vented, with Ferritic Nitro Carburized process for corrosion resistance
rear: 13.3 x 1.02 (339 x 26) vented, with Ferritic Nitro Carburized process for corrosion resistance
Exterior
Wheelbase (in / mm): 109.3 / 2775
Length (in / mm): 184.7 / 4691 – Coupe
184 / 4673 – Sedan
Height (in / mm): 54.5 / 1384 – Coupe
55.7 / 1415 – Sedan
Width (in / mm): 72.5 / 1841 – Coupe
71.3 / 1811 – Sedan
Track (in / mm): front: 60.5 / 1538 – Coupe
front: 60.5 / 1538 – Sedan
rear: 61.4 / 1559 – Coupe
rear: 60.4 / 1536 – Sedan
Curb weight (lb / kg): TBD
Weight distribution
(% front / rear):
51 / 49
Interior
Legroom (in / mm): front: 42.3 / 1074
rear: 33.5 / 850
Headroom (in / mm): front: 37.6 / 954
rear: 35.1 / 891
Shoulder room (in / mm): front: 54.1 / 1375
rear: 51.1 / 1298
Hip room (in / mm): front: 54.1 / 1374
rear: 44.5 / 1131
Capacities
Seating capacity
(front / rear):
2 / 2 – Coupe
2 / 3 – Sedan
EPA passenger volume
(cu ft / L):
83.9 / 2377
EPA trunk volume
(cu ft / L):
10.4 / 295
Fuel tank (gal / L): 16 / 60.5
Engine oil (qt / L): TBD
Cooling system (qt / L): TBD
